It is currently Sun Aug 17, 2025 3:49 pm
PostPosted: Fri Jul 25, 2014 3:00 pm
Last Name: Ensor
City: Springfield
State: Missouri
Anyone have any tips for masking a fretted fingerboard for finish? I have only done it once. My epoxy filler slipped under the masking tape and I had to pull all the frets and redo them. But I would like to fret my guitars before finish if I can figure out how to get a tight mask around them.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri Jul 25, 2014 3:31 pm
Frog tape.
PostPosted: Fri Jul 25, 2014 4:10 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Hey Chris
I find it unnecessary to mask the fretboard while pore filling. I've used epoxy, CA and various paste types.
I tape just prior to shooting finish and remove after last spray session. This way everything stays nice n clean.
Nothing wrong with leaving it on for curing cycle (I use nitro) and removing after buffing but I usually retape before the level and buff just to keep the board gunk free. Works for me.
To answer your question, I use one piece of quality tape on each side using my thumbnail to push the tape tightly
against fret. A neat job here ensures a perfectly clean fretboard with no blowunder. It may take me an hour or so
to tape but it's time well invested. Also I try not to stretch the tape as it tends to contract again later with the
result of giving the finish a place to shoot under. DAMHIK.
Ken
PostPosted: Sat Jul 26, 2014 10:41 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I find it best to check often. Most pore fillers and finishes are pretty easy to scrape away with a razor before they fully harden.
I usually mask..pore fill...check and clean up. Re-mask...lay down some finish..check. etc. Its a drag
PostPosted: Sat Jul 26, 2014 11:27 am
I mask the fretboard before I start finishing and don't remove it until I'm done. I use the green 3M 233+ masking tape and make sure that it is well sealed next to the frets by using a small stick I sanded to shape for that purpose. I've done this with Zpoxy and standard pore fillers. I would not do it with CA, of course.
PostPosted: Sat Jul 26, 2014 10:39 pm
Last Name: Russell
State: Michigan USA
You might look into 3M Fine Line tape. It is used mainly for custom panting and striping in the auto body field. I have used it a few times on fretboards and it will leave a clean sharp edge. It comes in a variety of widths and will conform to shapes very well. It is more expensive that regular masking tape but you will not get any bleed through or finish creeping under it. It also doesn't leave any residue when removing it. I used it any time I was doing stripes or 2 tone paint jobs and it is really the best thing to use if you want clean crisp lines.
Bob
PostPosted: Mon Jul 28, 2014 8:51 am
Last Name: Ensor
City: Springfield
State: Missouri
Thanks for all the advice. I will look into some better tape.
